Attribute form¶
QField creates forms similar to, but not equal to QGIS. The field widgets from QGIS are supported on a best effort basis and optimized for the mobile use.
Widget type | Support | Notes |
Text Edit | - HTML is not supported - Numerical input is enforced based on the type. |
Check Box | ||
Value Map | ||
Hidden | ||
Attachment | This field is combined with camera integration. It is also able to open other files like pdf and doc (if you have an appropriate viewer) Attachment (photo settings) | |
Date Time | ||
Range | ||
Relation Reference | ||
Relation Widget | ||
Value Relation | ||
UUID Generator | ||
QML / HTML Widget | ||
Others | Funding |
Editable¶
Remember last values¶
Suppress attribute form¶
The setting suppress attribute form is directly applied to the QField form.
Drag and drop designer forms¶
Configure a Relation Widget¶
The visual identification of the list entries are done via the Display Expression of the child layer.
Key handling¶
Many-To-Many relations¶
Configure Attachment Widget¶
It can be used to:
- show and take photos or add pictures from the gallery
- listen and record sound clips
- show and record videos
- show links to external files like PDFs or documents
The path should be set to relative. The pictures, audios, videos, pdf and docs are stored then in a sub-directory of the project, where the link stored in the textfield is pointing to.
QGIS 3.30 or newer is required for the audio and video functionality
In QField the attachments are displayed. By clicking the icons symbol the camera or audio record is started to update the pictures, videos or audios with a new media.
On synchronization the sub-directory with the pictures, videos audios, pdf and docs has to be copied as well.
The option hyperlink on the attachment widget will disable the camera functionality and enable a hyperlink to open a document (pdf, doc, ...).
Configurable attachment path¶
QFieldSync provides the possibility to configure the path of attachments.
- Go to QFieldSync plugin > Layers Properties
Use expressions to specify the path of the attachments. By default, pictures are saved into the "DCIM" folder, audio recordings are saved into the "audio" folder and videos are saved into "video" with a timestamp as name.
Configure a Value Relation Widget¶
The widget Value Relation offers values from a related table in a combobox. You can select layer, key column and value column. Several options are available to change the standard behaviors: allow null value, order by value and allow multiple selections. The widget will display a drop-down or multiple-select list of the referenced features.
Configure Conditional Visibility¶
Groups can be hidden based on an expression. This is useful when certain attributes are only required under certain conditions. As an example imagine mapping trees. Some of them might have a disease and you have a list of possible deseases. To not clutter the form with many fields, make a group and configure a visibility expression for a group "diseases". Add a field "desease" with a checkbox. Only when the checkbox is checked, the list of diseases will be available to you.
Let's see what we got on the field:
Define Constraints¶
Attribute fields can have constraints attached. Constraints are
expressions that needs to evaluate to True
(or 1
) in order to be
able to save the form. Constraints are configured on a per-field basis
and a description can be added that will be shown if a
constraint is not satisfied.
Common use cases¶
Define Default Values¶
Fields can have default values configured. Default values are inserted into the attribute form when digitizing a new feature. They are visible and can be modified as long as the field is editable. They can be based on the geometry or expression variables.
Additional variables¶
For QFieldCloud users, two variables can be used in expressions including attribute form's default values:
- @cloud_username
which returns the name of the currently logged in QFieldCloud user.
- @cloud_useremail
which returns the email address of the currently logged in QFieldCloud user.
Common use cases¶
Insert the current date and time:
Insert the length of the digitized line:
::: {#snapping_results} If you want to use the snapping results after drawing a line, you can use the [\@snapping_results]{.title-ref} variable. The following code extracts the value of the attribute [id]{.title-ref} of the snapping match of the first point of a line. :::
Search in value relation and relation reference widget¶
It is possible to search value in a value relation or relation reference widget using the magnifying glass next to the field.
Define the display expression for the concerned layers, this will be used for searching for features. This is configured under Vector Layer Properties > Display
Configure Auto-complete Value¶
The "Use completer" checkbox must be checked to be able to use the auto-complete in the value relation.
Here a video showing how it works on QField
Define QML Widgets¶
Custom QML widgets can be useful to integrate advanced actions into forms. In this example we define add a button that open a third-party map and navigation app. This is useful to open e.g. turn-by-turn navigations on the device-native app for the user.
import QtQuick 2.0
import QtQuick.Controls 2.0
Button {
width: 200
height: width/5
text: "Open in Maps"
onClicked: {
Qt.openUrlExternally(expression.evaluate("'geo:0,0?q=' || $y || ',' || $x"));
The geo
URI above is adapted to work with Android. For Apple Maps the URI can be changed to 'geo:' || $y || ',' || $x
