Configure Map Themes
The beautiful thing about GIS is that maps are dynamic. Layers can individually be shown and hidden and information can be presented more or less prominently based on the task at hand.
This is what Map Themes (before QGIS 3.0 known as Visibility Presets) are for.
Creating a Map Theme
Creating a Map Theme in QGIS is a very simple task.
Map Theme Configuration
  1. Style the map and layers to your requirements
  2. Save it as a named Map Theme
  3. Load the project on your device and change the active Map Theme
Change the active Map Theme
Switching Map Themes is possible from the Dashboard.
Use the Map Themes combobox to chose the active theme.
Change Map Theme
