Using additional fonts
In QField, you are able to use all the fonts you want.
There are two different possibilities to register additional fonts:
- By adding fonts (.ttf or .otf) on the device in the folder <device root>/QField/fonts; those will be made accessible to all projects and individual datasets.
- By adding fonts (.ttf or .otf) in the same folder as a given project file (.qgs or .qgz); those will be accessible only when viewing that project file.
